Help! incomplete image when I connect laptop to plasma
S
Stylezz
So I connected my laptop with my plasma for divx viewing pleasure (I thought)
I have a dvi-out from laptop to hdmi-in in the plasma. I properly connected it with a cable I found for it from Belkin, started mediaplayer for a movie, dragged the player into the plasmascreen, and what do I see? The image is only but a part from the total screen! :thumbsdow
How can I correct this? what did I do wrong?
(info: I set the software properties to 1024x768 for the plasma, which is it's native resolution, it's a samsung 42 S5H. My graphics card is an ATI mobility radeon 9600)
Thanks!
I
Isaac
Are you configured in your video output for dual display or clone mode? You would want to be in clone mode with your PDP as the principle display.
S
Stylezz
ok thank you, that was the problem, it's all fine now! :clap:
