K
kev120885
Hi everyone, I have just bought a Denon ADV-550SD Home Theatre System which consists of AVR-550SD AV receiver and a DVD-550SD DVD player. Ive coupled this up with a set of Mission FS1 6.1 speakers. Ive connected everything up (used the optical cable to connect the DVD player) and it all seems to be working fine, although Im a bit confused about which settings to use when Im playing various sources.
For example, I made a CD with a load of MP3s on and I used the DVD player to play it. On the amp, I could select either Dolby Pro Logic IIx or DTS Neo:6 but which is best when playing music? I then put a DVD film in and it automatically switched to Dolby Pro Logic IIx and it wouldnt let me switch to any other mode.
Also, I have a Soundblaster Audigy 2 NX external soundcard for my PC. There is a test function on the computer to test the speakers and it says front right front centre etc out of the corresponding speaker. For some strange reason, I can only get it to work on the front right and left speakers but not on any of the others, although when I play music from the computer I get sounds from all the speakers. So, Im not sure whether my amp or computer settings are incorrect.
Altogether, I wish to connect the following to the amp
TV (via RCAs from the scart)
DVD player for playing music CDs and DVD movies (optical)
Soundcard (optical)
If anyone could help me with configuring all the settings for the best surround sound I would really appreciate it as Im finding it all a bit hard to understand.
Kev
Soundcard (optical)
Kev
