Help in MULTI ZONE AUDIO SYSTEM,.....
sanchit.sood
I am almost done with gathering the equipment for my installation,
1> i need advise on the sending audio from my source to the 300metres away amplifier.
Also i would like to know
2>if i should keep my source and amplifier together and send several audio speaker cable 14awg to 300meters away distance just like that,
==or use step up and step up transformers,
or keeping the amplifier near the speakers and sending long audio signal to the amp in different zones, i need good quality and effective sound with not spending too much on cables for which i thought the following
==or use rane bb22 to covert unbalanced line signal to balanced and running through 1.5sq.mm double sheild braided pvc jacket mic cable. but cables will be very expensive.
==or using intelix balun and sending audio through CAT6 cable (and if the cable should be stranded or solid, plenum or general, shielded or unshielded)
Lastly if i want 3 keypads controlling one zone, can i just use one cat6 cable length and distribute data together in 3 or
do i need to run 3 different cat6 cable from source.
there is a function which can make all three work together but i need to know if i can use just single length of cat6 till the keypad area and distribut e ie.
I have a multi zone setup at my farm, where i will be using 6 zones.
System:
Nuvo Grand Concerto with 9 Oled keypads
Source: nuvo ipod dock, 160gb nuvo m3 server, satellite radio, denon professional cd/mp3 player.
Zone1: Drawing room,
Bose acoustimass 10 5.1 system with Bose sl2 for operating rear speakers wireless.
Yamaha rx-v2700 amplifier plugged into the preampout of the nuvo system
Zone 2: Small Garden behind the drawing room
Speakercraft bb835 amplifier, 8 channel 35watts pr channel
2 Bose Freespace 251
2 Bose Freespace 51
1 Bose Freespace DS100SE
1 Klipsh 2 way rock speaker
1 TIC GS10 speaker
Zone 3 Bedroom
2 ceiling speaker polk audio RC60i powered by nuvo inbuilt amplifier
40 watts per channel
Zone 4 Fountain Garden Area (400meters away from source)
Cat 6 cable going to the keypad 400mts away
Rane MA6S 6 channel Amplifier 100watts per channel @ 8 ohm
Jensen 6 a/v distribution amp
4 Bose DS100SE 100watts contious @8ohm
2 Bose Frreespace 51 ground speaker
Zone 5
Cat 6 cabling for 3 keypads?? individual possible?
Speakercraft BB1235 Amplifier ; 12 channel 35 watts pc @ 8ohm
4 Bose Ds100se speakers
4 Bose Freespace 51
1 Speakercraft 820 ROX speaker
1 TIC GS 10 Speaker
2 TIC GS5 Speaker
Zone 6
Cat 6 for 2 keypads
Knoll MR1250F Amplifier 12 channel 50watts 8ohm
Crown CP660 Amplifier 65watts 6 channel 8ohm
Kramer VM50AN audio distribution amp
6 Bose DS100SE
4 BOSE FREESPACE 51
2 ROCK SPEAKER
1 SOUNDTUBE XT850 GROUND SPEAKER
2 TIC GS10
3 TIC GS5
Please give your recommendationsand suggestions, and if i should do any improvements to my system. Thank you very much
sanchit.sood
I would like to add something.
I just came accross so many different stereo audio baluns like
Cyan says 2000ft distance and around $150 so a pair is $300
Niles it says 2500ft and 110$ a pair
MuxLab send signals till 5000ft 130£ a pair
Intelix 2500ft distance and a pair cost around $150
It seems a bit confusing, as there are so many. and there specs says to use UTP Solid, but dont know if it should be plenum or non plenum?
Also is it a better to use baluns than a coaxial cables, i mean cat5e and cat6 are lot cheaper than coaxial, but any comments?
Philips OLED807 Review, The High Price of Hi-Fi, Video Processors plus AV / HiFi News & More
