Help in making?
Discussion in 'Home Cinema Building DIY' started by AV nutter, Oct 17, 2004.
  1. AV nutter
    AV nutter
    :suicide: Hi guys need to make a scart lead to 5 bnc so i can run my crt pj so the scart need tp have on the end horiz syc and vert syc and the RGB any help welcome thanks in advance.mke Av nutter :thumbsup:
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    I could be wrong, but I don't think that's possible.... afaik H and V Sync are not passed on any of the Scart pins...... Check Here for further info.
    S.
  3. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    What are you trying to connect to the PJ ??
    Can you send RGB via the device you want to connect to the PJ ??
  4. AV nutter
    AV nutter
    Hi need to make a lead from a scart to go in to pj need to have h and v plus rgb
  5. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    What cosmic023 means is what piece of equipment are you trying to connect to the pj with the scart lead.......i.e., dvd player, Sky box, video recorder, sub-atomic dark matter generator... :rolleyes:
    S.
  6. AV nutter
    AV nutter
    R G B controll box all souces going in 1 box then scart to the pj to r g b but have an old crt pj so need h and v sync plus rgb
  7. AV nutter
    AV nutter
    OK on the front of my CRT pj i have 5 bnc ports for rgb h/sync and h/sync plus RGB comming from a rgb scart av box i need scart to 5 bnc
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    they do exist, I use one at work unless I'm mistaken, try RS components or Farnell
  9. AV nutter
    AV nutter
    thank you kind sir
  10. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    The one I use needs BNC adapters fitted but they are readily available as well.
  11. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi AVnutter,
    I'm sure Keene Electronics do leads as well, What sort of CRT PJ are you using ??
    http://www.keene-electronics.co.uk/
    If it's a Barco they do prefer a 1v P-P signal on the Port5 BNC connection, otherwise you could use a Keene Sync blaster which boost the video signal if it doesn't like a regular scart lead.
    I'm using an HTPC (Home Theatre PC) via VGA to connect to my Barco Data 801s (Port 3 9pin D-Sub)
    Let us know what PJ you have, and i'll see what i can do....
  12. AV nutter
    AV nutter
    its an old sony 1020
  13. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Ah ok thanks for the info.........
    I'm sure you could get away with a standard lead, try Keene and see if you can try a regular lead first. If that doesn't work a "Syncblaster" lead would most definetly work.
    Seems like you've already answered your own question.........
    http://www.avforums.com/frame.html?...showthread.php?t=106682&highlight=syncblaster
    http://www.avforums.com/frame.html?...showthread.php?t=106845&highlight=syncblaster
    Did you buy a "Syncblaster" cable ?? Did it work ??
  14. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    He did indeed buy a "Syncblaster" and it did indeed work . . . until it went phut a few days ago.
    Mikey, me ol' mucker, for the scart pin out check here http://www.syncblaster.com/gtmfytv.htm
    David
    PS
    For info he uses a Holdan HSR1000 scart switch box
  15. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Thanks for the updated info vizslaraner, helps when you get all the info !! :D
    That link has all the info needed on the scart section to wire up a scart to x4 or 5 BNC connectors.
    Well i hope that solves your problems ??
    Maybe the switcher is causing the problem ??
    Just a thought......
