Help in choosing Sony 49-55 inches
suresh92
During Black Friday I bought an LG 49nano86, but the blacks and in particular the local dimming are very bad.
I went to my local Sony shop and they offered me the following refurbished (Grade A) TVs:
  • XH92 55" at £720
  • XH95 49" at £699
  • XH95 55" at £799
  • AG8 OLED 55" at £949
Initially my budget was around £600 but after the experience I had with the LG Nano86 I am keen to spend more.
Which TV would you say I should go for this money? I am more oriented in the best price/value option.
Is it worth to go for the refurbished instead of brand new TV?
Thanks in advance for the help
Dodgexander
The AG8 is a bit expensive considering its a 2019 model. So I'd go for the XH95.
If you buy at a better time of the year you can get some really good deals, but now isn't the best time for them. Usually around spring/summer is better.
suresh92
I think I'll be patient and wait until spring for buying the TV then. I like quite a lot the XH95 but if I will be able to save some bucks in just some months, the wait is worth.
LG CX Best Picture Settings
