Help in AVR choosing
Discussion in 'AV Receivers & Amplifiers' started by zsolt320i, Aug 6, 2013.
  1. zsolt320i
    zsolt320i
    May 27, 2013
    7
    Hi Guys!
    I'm looking for a slim AVR 5.1, with good stereo sound quality and with good 5.1 sound quality.
    Could anybody recommend me one?
    Do you know any test?
    Thanks.
    Zsolt
  2. dante01
    dante01
    Mar 5, 2009
    45,636
    +10,871
    Your preference for a slim receiver limits your options to one of the following:
    Marantz NR1504 £400
    Marantz NR1604 £550
    Pioneer VSXS300 £210
    Pioneer VSXS500 £320
    Cambridge Audio Azur 351R £500
    I'd rate the Azur 351R as being the best option in terms of audio, followed by either of the Marantz models.
  3. PSM1
    PSM1
    Dec 20, 2008
    26,281
    +5,434
    What is your budget? What speakers do you have? Slimline receivers tend to be compromised in terms of sound quality for the price so if musical ability is really important then a full sized receiver will often be better.
  4. zsolt320i
    zsolt320i
    May 27, 2013
    7
    Hi!
    I have Dali Concept 6 series.
    And the actual AVR is Onkyo Tx-SR504
    What do you think is it worth to change the actual AVR?
    Thanks!
    Zsolt
  5. zsolt320i
    zsolt320i
    May 27, 2013
    7
