Help I'm new!
Discussion in 'Home Cinema Speakers' started by Bleach, Oct 22, 2001.
  1. Bleach
    Bleach
    Hi, just wondered if any of you guys can help me out. I'm just about to buy a Dennon 3802 amp and looking for suitable speakers to go with it. I've got a very demanding Mrs who wont let me put speakers in unless they're the size of a matchbox, problem! I've auditioned the Energy 5.2 system and it's bigger brother the Energy Encore and was very impressed with both. Are these any good as far as you know? and can I upgrade to buy additional rear speakers? Alternativly Mission FS2 flat thingies have got the approval, but can I add additional rears as they use a Mission unbilical system (Sorry if this has been asked before by the way).
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    My advice would be to make space for larger speakers by removing the Mrs from the equation...
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The Energy Take 5 package was reviewed by What Hifi in August and earned five stars plus "Best in Test".
    Others to look out for are the KEF eggs at £800 or £650ish if you know where to look which seem to be the current favourites.
    I use the Def Tech Pro Cinema speakers which are about 1000 retail but discounts are available and think that they are marvellous.
    I toyed with the idea of flat speakers at the rear but gave up the idea.
    Ian
  4. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    I've just installed the KEF "Eggs" and they really are good. Would the Mrs mind if you used a sub-woofer??
  5. Bleach
    Bleach
    You dont know how close you are with thatone mate!!
  6. Bleach
    Bleach
    I think she's ok with that as long as I buy her something as a bribe!
    I'll give these Eggs a demo I think, thanks for the help. Do you know of any websites doing a good deal on them?
  7. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    It would seem that everyone quotes the same £800 price and there is no advertsied discounting. You will have to negotiate.
    This has been the topic of a previous thread.
    Ian
  8. Guest
    You should listen to the Ruark system. This will go a lot better with this amp. I checked them out but couldn't afford them,but they were very good.
  9. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,678
    Inbetween Upgrades !
    +8,100
    I have the Mirage AVS- 500 Sub/ Sat system. It retails now for around £500 complete with sub. Given the confines of your room and your Mrs, this system wil suit both. I personally find it superb.
    Kev
