Help I'm dim..home cinema prob
Discussion in 'Home Cinema Buying & Building' started by Hadfield, Nov 8, 2004.
  1. Hadfield
    Hadfield
    Nov 8, 2004
    14
    My first ever message on the forum so please excuse my technical dimness.
    I have aToshiba sd 9000 b dvd player and want to have an 5.1 home cinema system off it. It does not have a scart socket. What do I need to buy to get this to work..if it will. I am not after anything hi spec just a budget speaker system. Will I need an amplifier? or do the speaker sets have that built in.
    Sorry again for the vagueness.
  2. saguk
    saguk
    Aug 5, 2002
    444
    You will need either:
    1) An AV Amp and a speakers (either a 5.1 package or 5 x speakers & a subwoofer)
    2) An all in one system that has an amp and speakers.
    Generally, option 1 will give better results.
    If you are interested I have a 5.1 Eltax set of speakers, brand new boxed I am just about to sell!
  3. Hadfield
    Hadfield
    Nov 8, 2004
    14
    Thanks for the quick reply. I am worried the dvd player I have has not got a scart socket and most systems I have looked at needs one. The speakers you are selling..will they need an amp? Plus I think they maybe a too expensive for my pocket..
  4. saguk
    saguk
    Aug 5, 2002
    444
    How is the DVD connected to the TV? - Svideo cable?
    For sound you would connect the DVD to an Amp using either an Optical or Coaxial cable.
    The speakers would connect to the Amp using normal speaker cable.
    I was looking for about £50 for the speakers, you can get a budget amp for about £100.
  5. saguk
    saguk
    Aug 5, 2002
    444
    If you are interested in the speakers, I will list in the AV Classifieds Forum here to make it offical. You can have first refusal.
  6. Hadfield
    Hadfield
    Nov 8, 2004
    14
    svideo seems to be the connection..thanks for the offer of the speakers, I will consider it but I need to check out my options first.
  7. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
    Forget SCARTs. If you don't have one don't worry. You need to drive the display (screen, TV) with a video signal via (say) SVideo or Component or RGB - this is for picture only - and drive an amplifier using a optical or coaxial digital audio connection. The amp will do the decoding to get you your surround sound. SCARTs don't carry multi-channel sound anyway, so you always need a separate audio connection to get it.
