HELP ... Identifying RGB scart on Philips TV
R
rmsdev
Can anyone help to indentify which scart scart on a philips TV is RGB enabled
I mean It's NOT labelled RGB, their are only signs on the back
so what is the sigh that identify the RGB Scart?
R
rmsdev
Well both SCARTS have this sign (3 dots in a triangular fashion)
But the user manual says EXT 1 is RGB
So???
Does that mean I have two RGB SCART ???
What happens if you connect an RGB output to a non-RGB enabled SCART? ... greenish tinge on the whole screen?
lynx
Senior Moderator
Normally something akin to [...].
