Help! Identify the Speaker Connection
Discussion in 'AV Receivers & Amplifiers' started by gazzaputt, Jan 25, 2008.
  1. gazzaputt
    gazzaputt
    Sep 17, 2002
    220
    +11
    I have a LG amp I inherited. It has speaker connections on the rear which are dual male kind of like bone shape.
    I want to connect a 5.1 system for my son's Xbox but cannot find the plugs needed.
    Can anyone identify these from my vague description? :lease:
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    If it is an all-in-one home cinema system, check that it has audio inputs e.g. analogue (red/white RCA phono connections) or digital which will be either digi-coax (RCA connection usually coloured orange) or a toslink connection for an optical cable.
    The speaker connections are for speakers only. From your description, I suspect it doesn't have audio inputs, in which case it won't be any use. The Xbox (and 360) are capable of outputing analogue audio (2.0 channel stereo) via the red/white analogue connections and also digital audio (for DD5.1) via an optical connection.
  3. gazzaputt
    gazzaputt
    Sep 17, 2002
    220
    +11
    Has the audio inputs but I need help on connecting the 5 speakers into it. Usually they are the clamp type that the bare speak wire go into but this as I say need some form of a female dual plug.
    It has a optical input that is why I want connect the Xbox into it.
  4. Adam Shaw
    Adam Shaw
    Oct 2, 2006
    760
    46
    London, where the Queen lives!
    +99
  5. gazzaputt
    gazzaputt
    Sep 17, 2002
    220
    +11
    Adam your a star! I've searched Ebay all bloody morning!
  6. Adam Shaw
    Adam Shaw
    Oct 2, 2006
    760
    46
    +99
    If I recall, they were the same cables as Sony used on their DAVS systems, but still worht a quick call to LG to confirm this.
    Adam
