Help identify my PJ Problem !
Discussion in 'Projectors, Screens & Video Processors' started by danjos, Nov 30, 2004.
  1. danjos
    danjos
    Feb 23, 2004
    193
    Hi all
    ive run up about 200hrs on my tx100 and ive started noticing that when watching films the picture will dim slightly for a second or two and then return to normal brightness ! Its fairly subtle and i dont notice it all the time but if im specifically looking for it then it seems to occur every few mins.
    Anyone had this happen on thier projector?
    Any suggestions welcome , thanks :)
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Lamp flicker ?
    Jeff :rtfm:
  3. danjos
    danjos
    Feb 23, 2004
    193
    is that a known 'phenomenon' (sp?) then ?
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    It certainly is.
    I've seen it on many makes of projector over the years. Some can flicker pretty fast, others quite slow. It's usually the lamp but occaisonally it can be the lamp ballast.
    It's sometimes hard to notice with video material if it's quite subtle. The best way is to put up a static image like Windows Desktop.
    Jeff :rtfm:
  5. danjos
    danjos
    Feb 23, 2004
    193
    is it considered a fault? can it be fixed? or do people just live with it?
    thx for the help btw :)
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    If your projector is still under warranty, I would ask your dealer if he would rectify the problem for you. I personally find lamp flicker really annoying.
    Jeff :rtfm:
