I finally managed to construct a ceiling mount for my panny, when i sat down to watch it the following happened:
I switched on the power by rocker switch. I pressed the standby button, fan kicks in and bulb lights up but ....... after about 10 seconds the whole thing switches back to standby and will not come back on unless you switch it off again by the rocker switch. Then the whole thing happens again.
Does this mean my panny has failed?
If so, do i contact Panasonic or the retailer? It is about 3 months old and only has 32 hours on the clock.
