Help! I need your advice!
Discussion in 'Projectors, Screens & Video Processors' started by benmilne, Aug 12, 2012.
  1. benmilne
    benmilne
    Aug 12, 2012
    Hello
    I am making a virtual mannequin. You may have seen them at airports and the like? I have done all the tests with an acer es522 which is ok for the tests.
    For the finished thing I'm needing a projector that can zoom in more so effectively project a torso sized image at about 6-8 foot.
    The projector could sit on its side
    The budget is maximum £600
    And it will be inside in a shop so not dark but not in sunlight.
    It will run for about 6 hours a day so bulb replacement costs might become a factor!
    With all due respect- before you think of replying 'it can't be done for less than £3000 with a diamond super max ultra screen' then don't. It is being done at the moment with a budget projector and the expensive £250 per metre film all I want to know is what would you recommend for £600! Sorry for the rant but I'm well used to forums!:)
    Thanks in advance!
    Oh and I am willing to look at second hand.
