As some of you know I have had trouble trying to sort out my screen without a tuner box.
Finally I think I am getting somewhere, I should be able to sort the picture out if i use a a scart to vga lead, the only problem is that I have been told that its not worth buying a standard lead from ebay, but to get a Q Sync one instead which costs 80 pound plus.
Does anyone know if there is another cheaper option that will work?
