Help I cannot close my DRH screen
Discussion in 'Projectors, Screens & Video Processors' started by martinnaylor10, May 4, 2005.
  1. martinnaylor10
    martinnaylor10
    This is my first post on the forum,after putting up my new DRH screen and being very pleased with it I cannot retract it,after spending the last hour trying (DOH!) :( can someone please help.
    Thanks Martin
  2. Kramer
    Kramer
    You need to "tug" it down quickly approx 3/4/5 inches (releasing the latching mechanism) & "let it up" quickly (before the latch re-engages). Just make sure you keep hold of it on the way up but don't slow it down to much...otherwise the latch will re-engage.
    A little practice & you'll get the hang of it in no time :smashin:
  3. wooski
    wooski
    Jan 23, 2006
    17
    3
    Thanks for that - I was just stuck for a approx an hour too. The problem is that you dont want to tug it too hard. Just reinforces that the screen has to be mounted very secuely with screws into ceiling joists.
