Help I am an idiot
Discussion in 'Portable Disc & Media Players & Recorders' started by millfield13, Apr 5, 2005.
  1. millfield13
    millfield13
    :oops:
    Ok probably should have checked it out more but i bought a Pioneer AVH P-7500DVD from ebay (it said UK)but it arrived and it's a US model. OK the radio im ok with odd numbers are fine, ok its region 1 DVD again not a problem.
    The problem is it has built in TV and guess what it's NTSC only.
    My question is can i buy a PAL to NTSC converter then run the 4 3.5mm jacks by converters to a single phono to the converter then out again from a single phono upto the 4 3.5mm jacks in to the "brain" ?
    And will this work or not? Or is there an easier way or should i forget about watching the Fimbles on the way to work?
    :lease:
    Incidentally this is the converter i was thinking of
    http://www.highway.net.au/parts/converters/4245.html
  2. Boy Lex
    Boy Lex
    No. You can convert NTSC DVDs if you like, but a converter is not going to allow you to pick up UK TV. We use a different number of lines and different frequencies and different frame rates that it just won't see unless its been designed for the worldwide market.
  3. millfield13
    millfield13
    Thanks for th reply i re-sold it on e-bay for more than i paid and i bought a Pioneer AVH-p6500dvd and a GEX-P6400TVP both English version so well happy now.
    Thanks anyway.
