help! hs50 from comp no movie playback
Discussion in 'Projectors, Screens & Video Processors' started by malariaboy, Jan 22, 2005.
  1. malariaboy
    malariaboy
    Dec 16, 2002
    1,854
    taunton somerset
    +120
    setup my hs50 today with a vga cable from my comp which has a 6800 gt graphics card, im running a dual view mode and can see everything on desktop . When i run any sort of movie such as a trailer or a hd clip it wont appear on the projector. any ideas
    cheers darren
  2. tomos
    tomos
    Oct 3, 2004
    135
    16
    at a guess it sounds like an overlay problem. last i heard, it could only work on 1 display at a time for some reason
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    That's certainly the most likely cause.
    With a 6800 you'll probably get a better PQ using the VMR9 renderer, this will be an advantage because that will display on both devices. If you need to stick to Overlay then set the HS50 as the Primary device using the nVidia Control Panel.
    BTW, what version of the nVidia drivers are you using?
