HELP How to remove Lipstick from a Dvd??
Discussion in 'Movie Forum' started by Herbal, Aug 13, 2003.
  1. Herbal
    Herbal
    Ok, My little girl got my G/F lipstick and decide to draw on one of my dvd's.
    Tried washing it with hot soppy water, usin a cloth, but still wont come off, has anyone got any ideas.
    My m8 said use Vodka, will this work?
    Any help would be great:D
  2. Marv
    Marv
    Jun 7, 2002
    2,677
    Kekistan
    +943
    Industrial Strength bleech, or a cd/dvd wipe.
  3. Herbal
    Herbal
    Hi i tried the Wipes, didnt do much
    Will the Bleach affect the dvd at all?
  4. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    The best thief you’ll never see.
    +6,514
    Have you tried window and glass cleaner, or Isopropanl Alcohol from the chemist?
  5. Squirrel God
    Squirrel God
    Try Autoglym Fast Glass (what you use on car windows) as it's non-abrasive, and wipe it off with something like a spectacle cloth or a regular 100% cotton cloth - don't use anything abrasive.
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    Post edited
    Ignore my blatant stupidity
  7. baldbird
    baldbird
    Ditch your Girlfriend or get a lock
    :p
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    see he read it as though it was your g/f drawing on your dvds too... not just me!
  9. baldbird
    baldbird
    No, I realised it was her daughter, but I reckon the scheming little minx enouraged her to do it:D :D :D
  10. Herbal
    Herbal
    Yeah she probally did, as it's one of my fave films
    The Rock - Nic Cage (Critroen)
    And she hates it, everytime she comes home i got it on, must have watched it a good 70 times
    Might chuck her hugh grant films in the mircowave, see what happens
  11. Squirrel God
    Squirrel God
    Sparks.
    Lots of sparks.
    :eek:
  12. mjn
    mjn
    May 24, 2001
    21,874
    Herts, England
    +9,556
    keep your daughter in a cage in future? :)
  13. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Any luck on this yet Herbal? Did you try make-up remover? :kisses: :kisses:
  14. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    +6,514
    Yes what about some feedback. I would like to know if anything worked or ruined the disc.
  15. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    BTTT for Herbal :D
  16. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    The funding for my cinema habit comes from making cleaning products...... i wouldnt advise anything beyond Isopropanol, the window cleaner is a good alternative since it is often composed mostly of this but be careful because it will often contain ammonia which could cause problems..... and for god sakes dont try nail varnish remover unless you are sure whats in it!
    Ad
  17. Herbal
    Herbal
    Sorry Everone, thought this had gone
    Anyway REPORT
    Glass Cleaner got most of it off, then i got my Glass Car cleaner and that got rid of the rest.
    But i used COTTON wool to get it off, then i used proper cd cleaner and
    WAY HAY
    Sorted:D
    Thanks Everyone :clap: :smashin:
  18. Squirrel God
    Squirrel God
    Squirrel knows best :D
  19. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    If you live near a Lidl store (most people do :D ) they do an absolutely brilliant cleaning cloth. It is light green in colour and it cleans and polishes dvd's and cd's perfectly without any trace of scratching. It comes in a flatpacked cardboard wallet and costs about a pound.
    I highly recommend this.
  20. baldbird
    baldbird
    but - what about the girlfriend - did you ditch her ?
  21. Herbal
    Herbal
    No just gave her a telling off..
    STAY AWAY FROM MY PRIDE AND JOY!
    She replied ' I thought i was'
    I said: ' You thought wrong then' :D
    I have over 350 Dvd's and all she does is put her fingers and prints all over them, and put's the last film i watched into the case of the one she's watching now.
    Took me a good hour to find Leon the other day, was in a bloody Disney film :mad:
  22. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    +6,514
    Mmmmm I think my suggestion was in there somewhere.
  23. Squirrel God
    Squirrel God
    Well you should've got in there and made sure he knew afterwards. I did. :D
  24. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    +6,514
    I wasn’t going to bother till I saw you claming it for yourself, without mentioning your mate.;)
  25. Herbal
    Herbal
    Guys, I thank you both very much
    [​IMG] [​IMG]
    One for each of you :smashin:
  26. Garrett
    Garrett
    Apr 21, 2001
    39,843
    2
    167
    +6,514
    Glad to help and that it worked Herbal. :smashin: ;) :cool:
    Back to the Isopropanl Alcohol I was once recommended it by a recorded dealer, as it a very mild alcohol and have used it for removing dust on records. It is sold as tape head cleaner as, yes, 'Tape Head Cleaner' in very small amounts and cost about £2. But if you ask for Isopropanl Alcohol at a chemist you will get a great big bottle for a few pounds (round about £3???).
    I have used both Isopropanl Alcohol and window cleaner on CD’s I have had from the library that have been mistreated and have been miss tracking with no problems.
    One day I saw the staff repairing some CD’s using Duraglit and a watered down Isopropanl Alcohol solution on CD’s that were badly scratched with success so I take it should work on DVD’s, well the Isopropanl Alcohol at least.
