Help! How do you remove a Radeon fan?
Discussion in 'Desktop & Laptop Computers Forum' started by uczmeg, Nov 14, 2004.
  1. uczmeg
    uczmeg
    May 18, 2003
    3,154
    71
    Nottingham
    +45
    I want to remove the stock cooler from an ATI Radeon 9700pro graphics card.
    However I have no idea how to remove it! It seems to be attached by a couple of pins with springs on them, however they seem to have no give.
    I don't want to bash away at them until I know how they should be removed.
    Can anyone offer some advice?
    Marc
  2. X-Factor
    X-Factor
    Nov 1, 2003
    57
    Scotland
    On the 9800pro the pins go through the card and you just use a set of pliers to squeeze the end on the pins until they go back through the holes. Don't know if the 9700 is the same.
  3. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    as x-factor says you need to squeeze the pins out, if not try very carefully slicing through them with a craft knife or similar.
    the heatsink will be glued on. i've found the easiest way to remove them is to put some cushioning right up to the heatsink across the pcb and put a flat head screwdriver under it and rotate slowly. this normally makes it give, apparently sticking it in the freezer in an airtight bag makes the glue more brittle. just be sure to clean it all off the vpu before applying a new one.
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    its thermal paste surely, not glue??
  5. uczmeg
    uczmeg
    May 18, 2003
    3,154
    71
    Nottingham
    +45
    Thanks guys. Once I realised the center of the pins pulled out it was easy to remove it.
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    My sapphire 9700 was thermal paste.
    If it does feel like its glued - heat it up with hairdryer and then twist horizontally.
  7. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    yep, not glue but it was as near as on my 9800 pro and 8500dv :)
