captainarchive
For some reason my keyboards changed it's setting. When I press the '@' key it comes out as ". If I want to enter @ I have to press ". how do I change it back to the UK setting?
Thanks that's done the trick. It strange how it changed mid sentence. It's not like I was downloading anything or rebooting? I'm going to run some anti-virus software now to make sure everythings fine.Sounds like you have it set to us keyboard.
you can change it in the control panel options.
Keyboard Layout - Change - Windows 7 Help Forums
That is probably what I did. I've now deleted the US option as suggested.Left Alt+Shift switches languages. Best bet is to delete the US keyboard altogether.
