HELP! Hitachi 32LD7200 connected to PC.
Discussion in 'LCD & LED LCD TVs' started by deanknox, Aug 27, 2005.
  1. deanknox
    deanknox
    Please help!!
    I have just bought a Hitachi 32LD7200 32" LCD TV and i'm overjoyed with it. I have it all connected up and working fine.
    I thought I would connect the LCD to my computer as it has a HDMI and a DVI-D [::::::::-] socket. My PC has a the usual connections at the back. VGA, S-Video and what I think is a DVI-A [::: ::: ::] socket (It has the numerous single pins with four individual pins around it). My problem is which cable to buy?
    I bought a DVI-I cable (Digital and Analogue I think?) but this would not go into the LCD as it didn't have the 4 pin slots around the flat cable.
    WHAT IS THE BEST WAY TO CONNECT THE TWO? Can you buy a DVI-A to DVI-D converter?
    Can anybody help me as no so called 'experts' in shops seem to know!
    Thanks in advance
    Dean
  2. rhubarbe
    rhubarbe
    May 25, 2005
    4,668
    Cheshire
    +211
  3. deanknox
    deanknox
    Can anybody help me with this still?
    I want to buy my cables today bt don't know what to do!
  4. deanknox
    deanknox
    Putting this back upto the top..... sorry i'm desperate for an answer!!
  5. DPT1976
    DPT1976
    Aug 24, 2005
    747
    43
    Essex
    +101
    What graphics card do u have? If it definatly has a DVI-A connection then there is no cable u can use to connect it. DVI-A is not compatible with DVI-D. However im pretty sure that your graphics card would be DVI-I so u would just need a DVI-D cable. Check this link - http://www.directron.com/dviguide.html#cabling
