G
gil2
1 minute i`m getting mission fs1 6.1 then i think ...nah canton cd1`s then the good lady says use the mission 73`s we already have , ahhhhhhh
if i use the mission 73`s for rear effect will i stll be able to listen to them using my existing nad amp for music , the av amp i have is a yam rxv450 , i havent plugged it in yet as i dont have a surround speaker package , so i`m not sure how clean it lets the audio from the nad amp through the yam amp , the book says it has a setting called direct stereo which allows you to bypass the units decoders and dsp processors for 2 channel pcm and analogue sources , is that just a straight through pass ?
god its hard deciding
what would u choose fs1 6.1 or canton cd1
