Quantcast
HELP! HDTV/Xbox/Recording help needed
U
uthustler
The problem is as follows. Trying to record on HDTV/Xbox, and I can't get it to work. It MUST have Component cables going into the TV to get the 480p resolution. My recording gear will only take composite or S-Video signal. The TV will not send a signal out if the source is component. I need a way to split the signal before it goes into the TV and convert it to either S-Video or composite. So I have component going to the TV and composite to the recorders.
Here is the link to the TV.
http://www.bestbuy.com/site/olspage.jsp?j=1&id=1051826204783&skuId=5335871&type=product
any help appreciated:smoke:
