Question Help - HDMI ARC Setup
Discussion in 'Home Cinema Buying & Building' started by TopDog0310, Oct 28, 2018.
  1. TopDog0310
    TopDog0310
    Oct 28, 2018
    Luton
    hi all,
    Apologies if it’s been answered already... I don’t think it has. I have a complex situation and I’m searching for the perfect setup.
    I have:
    • LG webOS TV 43UJ750V-ZB
    • Samsung soundbar HW-H450
    • Sky Q
    • Xbox one
    I am trying to run these through the HDMI ARC so all the sound comes from the soundbar and subwoofer.
    My previous setup was flawed; I had Sky running through the Xbox.
    I have decided against that now, and want them to operate independently of each other, so am now using a HDMI switcher.
    In both methods, when using Netflix app (etc) on the LG TV, the audio present is the Sky/Xbox instead of the Smart TV app.
    How can I work around this for the audio to play whatever is on display on the screen?
    Also, in the same room (connected to my PC), I have Logitech Z323 speakers and a small subwoofer. Is there anyway I can set these up to operate with the Samsung soundbar?
    In a perfect world, I’d still like these to play sound from the PC (when in use).
    Thanks guys
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,433
    If CEC/ARC is working for you there is no need for an HDMI Switch - connect your Sources to the TV then the TV ARC port to the Soundbar ARC port and configure CEC/ARC.
    Joe
