Help - Harman Kardonn amp in need of repair!
Discussion in 'AV Receivers & Amplifiers' started by jonfisheruk, Dec 3, 2003.
  1. jonfisheruk
    jonfisheruk
    My harman THX amp has been sitting idle for about 8 months in which time it has developed a fault where it trips out just after turning it on. Can anyone recommend somewhere to take it for some TLC?
    I need to get it fixed, (i'm hoping its simple!)
  2. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Send it back to HK they give a very good service!
  3. jonfisheruk
    jonfisheruk
    Thanks Brox
    Its from 97 so its quite old and second hand, do you think that they will still look at it?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What model??? They should do as THX amps are pretty high spec even that old!!
  6. jonfisheruk
    jonfisheruk
    Thanks Guys I will give them a ring tomorrow and see what the cost implications are :(
