HELP!! Harman Kardon HK3370 in Safe Mode - Not Working!!
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by RalphSolly, May 26, 2005.
  1. RalphSolly
    RalphSolly
    I own a Harman Kardon HK3370 Amp/receiver. It is not working. i have replaced one fuse inside the amp correctly, and the plug fuse. However the plug fuse keeps on going. When i switch the amp on it turns on standby but turns off when i try to turn it on properly. I have to replace the plug fuse and the same thing happens. Harman Kardon say it is in "safe mode". Any suggestions of how to solve this dilemna????
    Ralph
  2. Ru55
    Ru55
    Jun 12, 2005
    79
    Mids
    Sounds stupid but check your speaker terminals at each end.
    If they all look ok, could be a fault either end where the negative and positive terminals are making contact.
    I once had a faulty speaker where the crossover linked the polarities causing my amp to switch to safe mode.
