HELP!!! hack needed for cyber home ad-m512
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by BILLY, Sep 4, 2001.
  1. BILLY
    BILLY
    Hi there just bought a cyber home ad-m512 dvd player I can get into the secret setup mend (7,6 then sel) but I acn't seem to change the r code. Can anyone please tell me how to make my machine multi region!
    I read somewhere that I have to download new firmware then burn it onto a cd and upgrade it that way is this true?
    Thanks Billy
    [email protected]
  2. poolking
    poolking
    Sep 2, 2001
    35
  3. MattB
    MattB
    May 17, 2001
    189
    Essex,UK
    You need to upgrade the firmware - I am using 9.8
    Either buy the CD from Richer $ounds for £20
    OR
    Go here <a href="http://www.cyberhome-help.de/tadm512_english.php4" target="_blank">Cyberhome help</a>
    download the firmware and follow the installation instructions like I did. Version 9.8 gives you multiregion and (temporary) macrovision off.
    Good luck,<br />Matt.
