HELP!!! FUJITSU plasma with Digibox
Discussion in 'Plasma TVs Forum' started by Skillz, Apr 23, 2002.
  1. Skillz
    Skillz
    Hi, I was wondering if any of you out there could help me.
    I have Fujitsu 4242
    Sony Digibox
    and am awaiting Sony DVP -NS900 DVD player,
    I just wanted to find out if the screen would accept an RGB output from the DVD player using a 4 BNC RGB cable, as I have been told that it may need a seperate H and V sync. There is a terminal on the back of the screen marked H/CS but nowhere in the manual does it say anything about accepting a composte sync?......
    (and would it be better to get a cble which does have both H & V syncs)
    Also If i were to connect the Digi box to the DVD player using an RGB cable would this signal still be put through to the screen via the DVD player, or would I need to wire both up seperatly.
    Thanks for anyhelp
    Shilen
  2. ajmalsheikh
    ajmalsheikh
