Help from Panasonic PL10 owners ?
PaulBoy
Just bought one of these beauties to replace my "titchy" 28" (!)
Quite like to move my av stuff into the "open" stand that comes with the PL10 32" - How much can you get in ?
I have a 3801 receiver; Sky STB; VCR & DVD player - Any chance ?
TIA - Paul ;)
BTW Its the newer stand with one shelf (VS-32PL)
J
jag
I have the Panny PL1 but it has the same stand.
It is quite limiting. I have my Denon 2802 amp on the shelf and it moreorless takes up the whole shelf.
Underneath and sitting on the floor I have my DVD player with my NTL box sitting on top of that.
You are going to struggle to fit a VCR as well. You may have stand something up against the side e.g. Sky STB.
PaulBoy
jag - thanks 4 that - the Denons are huge unfortunately so I wasnt optimistic even using the space under the shelf which presumably has width for only one "midi" size component (VCR or DVD) ? Would a STB fit beside it under the shelf as the STB's are a bit narrower ? Even then where could I put the VCR (under the 3801 ? - probably crush it!)
Must find a way round this or 'er indoors will go ballistic :blush:
Paul
J
jag
To tell you the truth, and I know you don't want to hear it, but you're gonna be struggling.
At a push, depending on the size of the STB, you may be able to squash it in there somewhere.
The only other thing I can think of is have the STB on top of the tv? Assuming of course you haven't got a center speaker already there.
