Help - Freeview box resets when on ITV channels?
Discussion in 'Freeview & YouView' started by rgc_911, May 31, 2005.
  1. rgc_911
    rgc_911
    Mar 8, 2005
    9
    I have a old On Digital box with the slot, and in the last week it has has started resetting, or locking with a black screen when receiving any of the ITV channels.
    Usually does it with a couple of minutes.
    All BBC channels are fine!
    Is this a fault with the box, or the transmission on that Mux?
    any ideas
    thanks
    Cookie
  2. dts borg
    dts borg
    Sep 5, 2001
    578
    Hornchurch
    +8
    My father inlaw has the same problem with his On Digital box :confused:
  3. rgc_911
    rgc_911
    Mar 8, 2005
    9
    DTS_Borg,
    I notice you are in Hornchurch - as I am - is your
    father in law local to that area?
    Have you tried swapping the box with another one?
    thanks in advance
    Cookie
  4. dts borg
    dts borg
    Sep 5, 2001
    578
    Hornchurch
    +8
    He is in Collier Row and has no second box to swap with :suicide:
    I use a Free View DVB Panasonic box for my PC which is fine :smashin:
    Good Luck
