Help For Svhs Jvc Hr-s9700
Discussion in 'Digital TV & Video Players & Recorders' started by AAA, Jan 28, 2003.
Tags:
  1. AAA
    AAA
    I bought your exelent SVHS Video Recorder HR-S9700 in UK 6 month ago.
    It was working fine until today it start to record/show a picture, covered with noise, something like "colour snow"-small, moving horizontal red, green and blue lines/dotes...
    I have tried to play previously recorded on the same recorder tapes(which showed fantastic picture before), but with the same result!...
    I loved this Recorder, and now I am very upset!
    PLEASE, HELP ASAP!!!!
  2. Jerry Maguire
    Jerry Maguire
    Have you tried a Head Cleaner Cassette? See if that helps at all.
  3. AAA
    AAA
    No, I have never used Head Cleaner Cassettes on any of my VHSs....
    But, guess what...it shows fantastic picture again and as normal today! No Coloured Noice at all!....
    Any ideas what it could be the reason ?!....
    Thank you very much for your replies!
  4. Ben Hur
    Ben Hur
    A Ghost In The Machine :confused:.
  5. GaryB
    GaryB
    Nov 12, 2002
    5,341
    St Albans
    +1,264
    It was probably clogged heads. They often clear themselves. It's always worth trying reverse search when you get clogged heads. Reversing the direction of tape travel can sometimes remove minor gunge.
  6. AAA
    AAA
    Thank you GaryB,
    Thank you to All,
    Thank you to you too, Ben Hur?!....
    From what you said, it is clear that:
    1/ You have got a Wrong Name, as it is well known fact, that the Historical Hero Ben Hur has never said such a Nonsences !!!.....
    2/This Forum is for people, who Are Passionate about AV Technology, And Honestly share their experience and opinions !!!....
    .....And Not for Failed Comedy students !!!
    GaryB,
    Any ideas why JVC does not have a auto cleaning system in their VHSs, as Panasonic ?...
    May be the magnetic currents from auto cleaning system affect negatively some other systems...
    And is this system is so effective?
    Thank you,
  7. GaryB
    GaryB
    Nov 12, 2002
    5,341
    St Albans
    +1,264
    There are a couple of reasons that head cleaners are rarely fitted now. One is cost. I know it's only a few pence but when VCRs are as cheap as they are now, every penny must be saved. The main reason is that they don't work particularly well in the long term. JVC VCRs, along with many other brands were fitted with head cleaners a few years ago. They are just simple spinning mechanical foam brushes that are pushed onto the heads for a second or so when a tape is inserted or (sometimes) when play is selected. Since most people don't have their VCRs serviced as they should, over time, the foam brush fills with gunge from the head and ceases to be effective. It can actually end up putting previously removed oxide back onto the head which of course clogs them up.
  8. Ben Hur
    Ben Hur
    My pleasure kind sir :).
    Well, my full name is Judah Ben-Hur but I've never liked the Judah part of it so please don't tell anyone else.
    Until now.
    Yes, I know.
    So why are you here then?
    ps. Do you just throw in CapItAL LetTErs at random or is this some form of new language....perhaps Euro-English?
  9. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    This is a great VCR - glad you got it sorted :).
