Hi, I'm hoping I could get some advice on what I should go for when it comes to my future living room setup.
So the plan is to have a HTPC (Intel NUC of some sorts) to power either a 2.1 or 3.1 setup hooked up to what will probably be a OLED TV of sorts.
I think I'm settled on the Q Acoustics 3020i's and maybe the 3090ci center speaker but I would love some advice on whether I would need the center speaker or not. As for the subwoofer, probably the Q Acoustics 3060s Powered sub but again, I'm new to this so I would love some advice.
My current setup is my PC is hooked up to a cheapo Pioneer AV receiver which is hooked up to two little Bose speakers and a Bose Sub and the AV receiver is plugged into my cheapo TV.
It's done great for the years of use but I want to upgrade everything plus the speakers aren't mine and I'd be going from a bedroom to a living room haha.
Now I would just reuse my AV receiver but I think it will be too big and bulky for a living room media unit (plan on making everything discrete) and also I don't know if I'll get the best out of the speakers with it. But if I'm wrong and my AV receiver would be fine then I'll try and find a way around the space constraint.
What I'm basically getting at is would a 2.1 setup with a HTPC and a OLED TV be a great experience, or would I just be better off buying some decent soundbar/sub combo?
Or could I emit the AV receiver all together and just connect some bookshelf speakers and a subwoofer to the HTPC somehow and then have the HTPC connected to the TV?
