Help for Denon AVC-A10SE
Discussion in 'AV Receivers & Amplifiers' started by Grubert, Jun 15, 2001.
Tags:
  1. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    Hi everyone, I'm new here.
    I've just bought at a very competitive price the AVC-A10SE (because they're discontinuing it, I guess). It goes with a JM Lab Chorus set: 3 LCR 700s, 2 SR 700s and the subwoofer.
    My problem is that when I listen to stereo material (in Stereo or Direct modes), the subwoofer always fires, regardless of the Subwoofer mode setting.
    The retailer has reproduced this phenomenon on his display amp, so he says it is normal. Is it?
    Thanks a lot.
  2. dUnKle
    dUnKle
    Jan 1, 2001
    13,379
    +1,325
    When listening in stereo ( or direct ) change the volume off the sub to OFF
    To do this you have to lower it all the way past -12db
    Im just listening to the new JLO album and the sub is going CRAZY on -12 but definatly goes off when i take the volume lower
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    I assume you have your fronts set to LARGE, otherwise the bass below 80hz is being sent to your sub so you will need it on.
    Also check that the bass redirction is set correctly for your taste. If your rears are small you may prefer sedning their bass to the sub, rather than to the sub and fronts, if it's set like this.
    Rick
  4. Matty N
    Matty N
    Just to confirm, this is right and it is designed to do this. I can't confirm the exact mode of operation on this unit, but you could probably guess!
    Thus the unit will operate with full range hifi speakers or a sub-sat system for high quality stereo as well as HT.
    Regards, Matt
  5. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    Yes, I have all speakers set to Large. I think I'll just turn down or switch off the subwoofer when listening to anything not demanding a heavy bass load.
    Thanks to all.
