Help for a thicko
Discussion in 'LCD & LED LCD TVs Forum' started by ROY_H, Dec 2, 2004.
Tags:
  1. ROY_H
    ROY_H
    Nov 30, 2004
    98
    +4
    I'm new to the LCD TV scene, but interested in the Philips 32PF9986. Can anyone explain, does it accept prog. scan component or not. I bought my Denon 2200 DVD specifically with the aim of a future upgrade to a prog. scan TV.
    I can't seem to get a clear answer from any of the reviews or forum inputs regarding this.
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Hi Roy, I don't own one (went for a Sharp instead) but from memory, it's a yes on both counts. HTH :)
    Jud
  3. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Actually, just checked the Philips site here 32PF9986 spec looks like its progressive vis DVI. sorry! :rolleyes:
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    The late models take progressive component via the analogue circuits of the DVI-I input. You need to be looking for V2 or greater of the firmware that enables the component input. Philips supply cables to connect component to DVI-I. What the quality is like, I have no idea. It all sounds a bit of an after thought so component may not have been optimised for quality.
    There is another (long) thread that goes into this in great detail. Basically, the gist is that quite a few people got shipped the non V2+ version and couldn't get component to work. The clue was no component -> DVI-I cable was shipped in the box. To get the functionality of the earlier boxes enabled, the sets are having to be returned for upgrade. All credit to Philips, this appears to be FOC.
    So if you do purchase, ensure you get >= V2 firmware.
    -Ian
