Help For a Newbie - Samsung LW22N23N or Philips 23PF9946?
Discussion in 'LCD & LED LCD TVs' started by adamevo, Jan 3, 2005.
  1. adamevo
    adamevo
    Hi all,
    I've been doing a bit of research over the last few days on which LCD TV I should buy in the 22-23 inch size range for less than £700 (could go bigger but the price is limiting factor...).
    I've come to the conclusion that I should go for a 16:9 one which includes a HDCP compliant DVI connection for future compatibility which SKY HDTV etc.
    This has taken me to a short list of only a few TV's:
    Samsung LW22N23N (looks the nicest out of the two Samsungs)
    Samsung LW22A13WD
    Philips 23PF9946
    Can anyone confirm if they will indeed be fully HDTV compatible (I'm not 100% sure about required resolutions and refresh rates) and/or give me some advice on which one I should get, or suggest any other alternatives in my price range?
    Thanks for any help.
  2. wdrury_uk
    wdrury_uk
    Interest on thoughts on the Philips 23PF9946 :lease:
  3. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    Can you get the LW22N23N for that price?
