help for a french girl
Discussion in 'Home Cinema Building DIY' started by priska, Dec 13, 2003.
  1. priska
    priska
  2. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Hi Priska
    Welcome to the forums.
    The driver you are looking at has a 'relatively' high Free Space Resonance of 37.2 and is quite expensive for a 10" driver. It's key feature appears to be it's very high power handling capability of 500w which is not of any interest to you with a 200w amplifier. A much better option would be the Peerless XLS10 driver, which is widely recognised as one of the best 10" drivers available.
    BK Electronics have the XLS10 on offer with the amp here:
    http://www.bkelec.com/Diy/xls10.htm
    They also used to do the XLS 200 which is the above components built into a finished sub.
    http://www.avforums.com/forums/showthread.php?s=&threadid=99017&highlight=XLS200
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    The cheaper BK driver (12-100?) is that used in the REL Q100, by all accounts - there was a couple of good threads here a while ago on building these chaps. Perhaps that might do - even a pair of them if you're worried about getting enough sound level :)eek: )
    Try these threads:
    http://www.avforums.com/forums/showthread.php?s=&threadid=84564
    http://www.avforums.com/forums/showthread.php?s=&threadid=85278
    also do a search in this forum for "q100e" (no quotes) - that should find you plenty to be going on with!
    Richard
  4. Bluelaser
    Bluelaser
    Translation:
    Bonjour Priska Bienvenue aux forum. Le conducteur que vous regardez a 'relativement 'une résonance libre élevée de l'espace de 37.2 et est tout à fait cher pour un conducteur de 10". C'est le dispositif principal apparaît à que ce soit la puissance très élevée manipulant des possibilités de 500w qui n'est pas d'aucun intérêt à vous avec un amplificateur 200w. Une option bien meilleure serait le conducteur XLS10 peerless, qui est largement identifié en tant qu'un des meilleurs conducteurs de 10"disponibles.
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    We can all use Google translation tools, you know.
    Not actually sure that the translation for speaker driver is the the same as the driver of a vehicle :)
  6. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    you should try internet translators multiple times through various different laguages for a laugh - eg type a sentence, change it to Japanese, back to Hungarian, over to German, then into English again. You can waste hours of productive time doing this kind of thing!
