Help finding Large screen (60" + )
Discussion in 'Plasma TVs Forum' started by nitrusoxide2k1, Jan 10, 2008.
  1. nitrusoxide2k1
    nitrusoxide2k1
    Dec 14, 2004
    26
    Im needing to replace my Toshiba 57" screen with a new model of screen
    (Plasma or LCD), I have been offered a 52" Samsung full 1080, but I would
    like to either go same size or larger than 58", has anyone got any recommendations ? I have looked at the sony 70" but i believe that is a poor set and rear projection (like my bulky tosh)
    All help appreciated, thanks in advance
    N20
  2. Pioneer Man
    Pioneer Man
    If you want the best screen at this size then you need to take a look at a Pioneer PDP-LX608XD, but then I would say that....
  3. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,422
    Excellent screen but expect to pay upto 5k for one.
  4. g852
    g852
    Dec 22, 2005
    601
    +25
    Depends what you want to pay?
    Whats your budget?
  5. nitrusoxide2k1
    nitrusoxide2k1
    Dec 14, 2004
    26
    around the 2500 mark, but no more than 3k
  6. g852
    g852
    Dec 22, 2005
    601
    +25
    For that budget, you'll be very limited as to a 60"+ screen. Plasma anyway.
    There is the LG 60" for around the 2k mark i believe, and for around the 3.5k mark, the Samsung 63"
    And the 58" Panasonic for around 3k.
  7. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,422
    I think you'll be struggling, the only 60" plasmas around that price range are from LG. LCD's really only go upto 52" .
  8. punkymunky
    punkymunky
    Jan 16, 2007
    610
    46
    +170
    If you want big a projector may be a better and more cost effective solution
