Help finding 23-26" LCD
Discussion in 'LCD & LED LCD TVs Forum' started by Roost, May 25, 2005.
Tags:
  1. Roost
    Roost
    May 25, 2005
    74
    Hi, i've been looking around trying to find a LCD TV around that size to replace my standard CRT. I'm looking for something that will cover 720p and 1080i as well as having a HDMI connection. I was looking at the latest samsung 26" on Digiuk, but there doesn't seem to be too many reviews at all.
    Don't all go for the biggest as i'm really not fussed about it being too big as i have a projector for that :)
    Thanks for any help you can give!
  2. peahead
    peahead
    Dec 14, 2002
    2,999
    St.helens
    +384
  3. Roost
    Roost
    May 25, 2005
    74
    Hi thanks a lot for them, they look great :)
    I'd be looking to use the next gen of consoles on it in the future but also the current gen, what would be the best way to connect them up as i don't think either has component :(
  4. supermackem
    supermackem
    Feb 20, 2005
    2,151
    sunderland
    +78
    I have just went for the toshiba model. Current gen would be rgb scart mate thats what im hooking mine up with. And keep the hdmi socket free for ps3/xbox360
  5. Roost
    Roost
    May 25, 2005
    74
    Thanks for that :)
    It'd be perfect if it only had component so i could use my modded box on it :(
  6. Roost
    Roost
    May 25, 2005
    74
