Help file missing
Discussion in 'Computer Software & Operating Systems' started by dts197, Apr 28, 2007.
  1. dts197
    dts197
    Aug 12, 2006
    4,922
    +668
    Over the past few days I've been having trouble with when opening up programs on my pc.
    I don't know how but I think a help file has been deleted. The "What's this?" (help with dialogs) can't be used.
    When I open up the control panel, I get a message come up saying the help file context.HLP is missing from my programs folder. When I try to locate it, the pc just freezes up.
    I think this is the reason why I can't connect my iPod to iTunes anymore as when I try, it says I don't have the right privileges (even though I'm an administrator of the pc). I can't even unistall iTunes either.
    I also get the context.hlp message sometimes when I open up Microsoft word.
    I've searched the net for answers but not been able to find anything helpful. Can anyone please help? Anybody know anything about how I can sort this or know somewhere I could get info from.
    I have tried a system restore to when everything was ok but has not helped.
  2. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    I don't think one simple help file is causing all your problems. I would start by doing a complete system scan for viruses/malware/spyware/adware.
  3. dts197
    dts197
    Aug 12, 2006
    4,922
    +668
    I did that first and removed everything it picked up.
  4. Stiggy
    Stiggy
    Dec 7, 2004
    6,728
    Sandy Heath
    +1,043
    So, it DID have some nasties on it then? Just because they have now been removed it doesn't mean the problems they caused have now gone away.
    I haven't got an XP PC to check with, but you might just be able to replace the context.hlp file from another PC. However, I think a wipe and reinstall of XP might be a better bet.
  5. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    I'd (always) suggest re-running XP SP2 before you start from scratch, very nearly the whole help&support system got updated, so it may well replace any duff files on your system. :)
  6. dts197
    dts197
    Aug 12, 2006
    4,922
    +668
    How do you re-run XP? Just put the disc in & install over the top? And it wouldn't affect any saved files in My Documents? Thanks.
  7. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,241
    Sorry...... NOT reinstall XP, reinstall Service Pack 2.
    If you download the 'full' ( or 'admin') version, it will be around 280MB in size.
    Download the file, try run it, and see what you get..
    Re-running the service pack can't hurt anything else, at least not permanently.
    Always worth a go before you start re-formatting. :)
  8. Stiggy
    Stiggy
    Dec 7, 2004
    6,728
    Sandy Heath
    +1,043
    Oh, and backup your personal data first!
