help export edited movie to camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dood, Jun 24, 2002.
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Please help if you can. I have a Canon MV 300 DV cam, originally only with DV out. I have used the hack from Smart DV to enable DV in and this seems to be OK. I have edited movies on my PC that I now want to take back to the camcorder. How do I do this? I am using Windows Movie Maker. I don't have Adobe, Pinnacle, Ulead movie software, only their "photoshop" stuff.
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Presumably your are using Windows Me with Windows Movie Maker.
    Its a long time since I had Me loaded on my system, but I'm 95% certain that you can't export with WMM.
    I think the only solution is to buy the cheapest editing software that has this feature. Try the Ulead software.
  3. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    dood,
    JefUK is right WMM cant output DV via firewire.
    There is a freeware untility called DVIO that can simply
    capture or send avi files via firewire, it hasn't got any cam
    controls so you need to start/stop/record etc manualy on the
    camcorder but it should get you started.
    You can get it from ...
    http://www.car-engineering.com/divo.htm
  4. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Thanks for your responses. Looks like I'll have to get some dedicated software. I might just try out a free trial period first. I tried the link above for DVIO but can't access the page.
  5. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    The page takes ages to load on my PC at work,
    the actual download file is freeware & only about 32k,
    if you want I can email it to you.
    mail me if you want this.
