Help: DVD Writer???
Discussion in 'Desktop & Laptop Computers Forum' started by WBC, Sep 14, 2003.
  1. WBC
    WBC
    Guys,
    I'm in the market for a DVD writer. These two have caught my eye and have pretty good reviews. I will be mostly using it for burning home movies, wedding videos etc so will want them to be able to run on All if not Most standalone home players.
    I thought for this sort of money, it makes more sense to go with a writer that supports both - & +!!!!!
    Which shall I go for or any better recommendations????
    NEC ND1300A £105
    http://www.novatech.co.uk/novatech/specpage.html?NEC-ND13SP
    Sony DRU-10A £140
    http://www.novatech.co.uk/novatech/specpage.html?SON-DWU10A
    The Sony is OEM but the NEC is boxed with Pinnacle software.
    Stace
  2. Insp.Gadget
    Insp.Gadget
    Dec 4, 2002
    132
    South East
    +3
    The Sony is Here for £117.50.................Looks like good reviews on it as well.
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    The NEC is being banded around as a good 'un.
    There is a compatibility list for media at www.bigpockets.co.uk courtesy of another forum member elsewhere, (sorry forgotten who already:blush: ).
  4. Garrett
    Garrett
    Apr 21, 2001
    32,242
    2
    167
    The best thief you’ll never see.
    +4,198
    The Nec 1300 seems to have some compatibility problems with some disc look here how many will not use it here
    An other DVD writer to consider is the Pioneer 106 OME or the A06 retail it will writ both DVD-R and DVD+R
  5. WBC
    WBC
    Anymore 4 anymore???????
    You would beleive hoe drunkk I am for a Grown man!!!
  6. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Do a search for coments from Sony owners...support seems to be less than good and it may be picky about some types of media. Check out the situation regarding firmware updates.
  7. Iain Shields
    Iain Shields
    Oct 19, 2001
    786
    N.Ireland
    +3
    Hope you've got a few headache tablets in the house for the hangover your bound to have when you read this :zonked: :suicide:
  8. Garrett
    Garrett
    Apr 21, 2001
    32,242
    2
    167
    +4,198
    If you do go for the Sony the have then at Scan on offer till 10am today maybe longer £117.44 here but the Pioneer 106 is on sale for £125.73 till 11.30 am at Micro Direct here
  9. WBC
    WBC
    I've had a look at different sites and they seem to think the NEC is pretty good.
    I'll probably buy this week.
    Where's the best place to purchase media??? Is it worth upgrading the firmware on this drive???
    Stacy :D
  10. Garrett
    Garrett
    Apr 21, 2001
    32,242
    2
    167
    +4,198
    Stace did you look at this site here and look how many disc are recommended not to be used with the NEC?
    Oh and they are cheap disc there.
  11. WBC
    WBC
    Garrett
    Thanks for the info. Not sure what to make of it now!!!! :confused:
    Why will these discs not play in that player????? Does it really matter with that amount of variety to choose from???
    I'm very very confused!
    Stace :D
  12. Garrett
    Garrett
    Apr 21, 2001
    32,242
    2
    167
    +4,198
    I would look at the prices of the blank disc that is compatible with the NEC and the disc that will burn on other machines.
    I do not if you mean burn by play but there are nearly always some computability issues, but I can play a CD-RW in my DVD but not on my CD player. Also I think there are issues with some burners and the speed of the blank disc.
    I also have a CD Rom that will play in my parents DVD player but not mine.
    As you say all very confusing.
  13. Garrett
    Garrett
    Apr 21, 2001
    32,242
    2
    167
    +4,198
    Stace
    I have just found out something, I cannot erase a CD-RW and thus looks as though I will not be able to burn on the with my 106 as they are single speed burn disc. Something I never took into consideration.:(
