Help DV-DVD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by nyck, Jul 12, 2003.
  1. nyck
    nyck
    May 2, 2003
    35
    I've put a few clips from my camcorder to my PC using MM2 .Itried DV-AVI setting but the picture was poor ,then i tried lower srtting all OK.
    I'm stuck how i now Get that on to DVD.I tried Nero but it was asking for Video TS/Audio TS any giudes or advice welcome or alternative software.
    AMD XP2600
    512M/b RAM DDR333
    FX5200
    DVD writer Pioneer 105
    thanks nyck
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Video_TS folder is what will contain your .VOB (Video Object files)
    Audio_TS folder is for DVD-Audio discs so won't concern you. To create your VOB files (Which contain your MPEG-2 video & your audio) you will need a DVD authoring program.
    Nero is essentially a burning program & I don't use it so I can't even tell you if it has any basic encoding or authoring capabilities.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Well a quick look at their website shows you can buy a plugin MPEG encoder to encode your video for SVCD (not DVD Resolution MPEG) , mentions nothing about authoring.
