Smurfin
I've been using Dune products for several years now, and I have three setups in my house with Dunes, all using Yadis to play movies from my unraid server.
Everything was working fine until I got back from holiday over the weekend. All of a sudden none of the Dunes can access ANY folders on the unraid server.
I get the same error every time I try to open the folders I've already setup, which is something like "Cannot open folder".
When going through Network Browser on the Dune, I can see all of my folders, but whenever I try to open one of them, I get the following error (picture in post #2)
Network resource is not accessible.
You might not have access permission
There's then a user name (guest) and password (blank) box...changing the values or clicking retry just gives me the same error every single time.
This is what I've done:
Dune:
Updated firmware
Cleared flash memory
Factory reset
Checked network settings (players show as connected - all looks good)
UNRAID server:
Checked unraid permissions: guest is set up with PUBLIC access, and no password set.
SMB service is running (tried switching it off then back on again)
Updated unraid O/S to latest version.
Restarted server.
Despite the above, none of my Dunes can access the shares, neither can I open shared folders on my main windows PC.
All shares are visible and accessible from my PC and laptop (both running windows 10), just not from the Dunes.
I've also activated NFS on the server, and I can't connect via this method either (same error).
The only thing that's changed in my setup is that the day we went on holiday I switched the unraid server off, and the router was off briefly also (I've also tried rebooting the router with no success).
I'm completely stumped and utterly frustrated, as I cannot see why this isn't working. Everything looks good within unraid, and the settings look fine in the Dune...but NONE of my players work at all.
Any ideas?
Matt
Dune:
Updated firmware
Factory reset
UNRAID server:
Restarted server.
Any ideas?
Matt
