Help!, Dish to Skybox same cable with HD ?
Discussion in 'Televisions' started by Ross-P, Mar 17, 2005.
  1. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    I don't know if this has been answered but I haven't seen it anywhere. I have just had my sky cables recently neatly chased into my lounge wall, so I was wandering when Sky HD comes out will I need a different Dish or cable (from dish to HD box) ?. I won't be a happy chap if I do!.
  2. howesey
    howesey
    All that will be required is a new LNB.
  3. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    Thanks I was getting worried!
  4. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    new lnb, why?
    i can get HD1 from astra 19 on a standard universal lnb, why should the sky HD service be any different, am i missing something?
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Unless there is something drastic in the pipeline then the only reason to change a SKY D LNB is if you currently have a single unit and like SKY+ before it you need at least two feeds.
    If you already have a twin or quad LNB then it should be a simple box swap out:)
