Help : Digital Scan / Progressive Scan
Discussion in 'General TV Discussions Forum' started by williamka, Jun 26, 2002.
  1. williamka
    williamka
    I have a SHARP 76EF20H,
    Its features include :
    Double Scan (100Hz - Line Flicker Reduction) Digital Scan
    Now the confusion lies with progressive scan and can this TV accept this type of signal, I would like to run a console in this mode.
    I know digital scan is an alternative to progresive scan but if I had a tv with progresive scan would I notice any difference since digital scan does a similiar thing only it does it at the tv. can anyone give me the low down on this.
    On a side note.
    This model didn't stay on the market for long anyone know if their was a specific reasn I should be aware of?
  2. rimmers
    rimmers
    Jan 30, 2001
    82
    Sutton Coldfield
    +4
    I have a Panasonic TX32PB50 which has 100Hz advanced digital scan and progressive scan so I think that digital scan is not the same as progressive scan.
    100Hz digital scan refreshes the screen at twice the frequency of a normal set (50Hz) and progressive scan displays all 625 lines of a screen in one go instead of the image being interlaced.
    Neil
