HELP! Digital coaxial out from Sony Freeview not working!
Discussion in 'Cables & Switches' started by Kopacabana, Mar 23, 2006.
  1. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    I'm at my wit's end!
    I have a Sony Freeview box which I want to connect to the digital coaxial in of my Sony surround system.
    The output from the Freeview box requires a 3.5mm jack so a guy at Maplin advised me to buy a mono 3.5mm jack-to-coaxial pin. I've plugged it all in and can't get a sound. What's going on???
    I've spent almost a year researching the bits and pieces I want for my home cinema system and I can't get the thing connected!
    Help!
    :suicide:
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    What models are you trying to interface?
    Have you looked through the menus to see if you have to turn the o/p on?
    Gareth.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,733
    Somewhere in South Yorkshire
    +6,311
    I suspect the digital output on this box is optical. Without seeing one, it may be either:
    - a separate port, not the 3.5mm jack socket you describe. Usually a small square and often protected by a plastic dummy plug in the hole. In which case you need a standard TOSLINK (optical) cable*.
    or
    - combined with a 3.5mm jack (as on many portable DVDs). In which case you need a mini-TOSLINK cable*.
    * with the other end depending on whether you have a spare OPTICAL input on your amplifier. If yes, it will almost certainly be a standard (square) optical connector. If you only have a wired (coax) digital input, you will need an optical > wired converter.
    EDIT: Another look at a web spec says the optical out is combined with the analogue out. Which suggests it is the second "or" above. Do a search for TOSLINK at Maplin.co.uk to find options, cables, adaptors, etc
  4. RBJTech
    RBJTech
    May 7, 2004
    583
    43
    Kent, England
    +101
    Hi - See Attachment - this is a toslink to 3.5mm optical convertor that plugs into the back of the Sony Freeview box (I have one too..) The only place I could find the converter was bundled with a Toslink cable - I seem to recall it was from Curry's/Dixons - definately a high street superstore. I hope this helps.
    Also please remember that this is Dolby Digital 2.0 ONLY - it is NOT 5.1 !
    Hope this helps !
    Richard.
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    Sound like you are talking about the Sony VU-800 Freeview box, if so it has the 3.5mm minijack (combined anlg & toslink output) if so you will need one of these :
    http://www.tvcables.co.uk/cgi-bin/t...Digital Optical Cables/op=eq.html?id=XzhHXn3B
    Many laptops use this connection ie combined 3.5mm anlg minijack & 3.5mm minijack toslink output. For digital output you need a Toslink cable (optical) with a 3.5mm minijack end and a Toslink end.
    PS you are perfectly within your right to take back the coaxial anlg cable you bought from Maplins as you were advised incorrectly about what cable you required. Just ask Maplins to swap for one of these :
    http://www.maplin.co.uk/Module.aspx?ModuleNo=35921&criteria=Toslink&doy=24m3
    HTHs
  6. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    Thanks for all your help guys, it's much appreciated!
    Hope I can get it sorted out this weekend!
  7. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    BUt why doesn't my digital coaxial work?
  8. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    You havn't given us the model number...
    If I assume you have the VTX-D800U , then the socket is a combined analogue stereo/ 3.5mm mini toslink optical SPDIF o/p.
    This unit does not support coax SPDIF. If this is the same as your unit, then you've just not got it...
    My reference was http://www.npe.sony.co.uk/manual.pdf
    Regards,
    Gareth.
  9. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    Thanks Gareth - you're right. Guess I'll have to throw my digital coaxial in the bin.
    Anyone want it?
  10. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    No problems...
    Dont let go of your interconnect... Just gives you another excuse to buy another componant for your system ;)
    Gareth.
