Help - Denon500sd
Discussion in 'Home Cinema Buying & Building' started by AKCooper, Jun 28, 2005.
  1. AKCooper
    AKCooper
    There may be a realy simple answer to this one.
    I have just bought the Denon 500 and it is excellent however I am suffering from some confusion regarding connections.
    I have the folowing components that i need to link up:
    Panasonic CRT
    Denon 500
    Pace Sky digibox
    JVC VCR
    So far I have got sound from the DVD player and TV from connecting the SCART from the Denon to the TV. However I can't for the life of me work out how to get sound from the Skybox. I have tried connecting from the TV and the Skybox with phonos to the Denon but no avail. I can get audio from the Skybox when I connect the Denon via the TV's AV1 however it only gives a RGB signal so is unwatchable.
    Anyone got any advice?
