Hi all.
I was hoping someone could help me.
I have a Denon AVR X4400H which is 3 years old and typically 1 month out of warranty when the problem occurred last night!
My rear bookshelf speakers are blown. I think. Whenever i watch movies and seemingly only movies, i get a crazy amount of distorted low rumbling bass. Feels like the house is shaking during explosions in movies! Anyway, i was watching a film last night and instead of turning the volume down every time the action got loud i just decided to unplug the darn things. And that's where the problem started! When i pulled out one of the banana plugs (the negative) it accidently touched the LF terminal below it while the positive was still plugged into the HF terminal. I saw a minute blue spark as it touched. Nothing immediately happened but as the film went on my AVR randomly turned itself off. I turned it back on and it was fine for several minutes and off it went again. Each with the red flashing standby light on. Eventually it was turning off more and more faster and now it no longer turns back on. Well, it turns back on for about 2 seconds before shutting off again with the flashing red light. Seems like some sort of protection mode. I noticed the top was extremely hot. It's normally very hot but i thought that was normal. Last night it did feel slightly hotter than normal though.
I unplugged it and left it off all night and the problem is still there. I tried the factory reset but that did nothing.
I took the cover off and saw lots of white stuff around what looks like capacitors. Is this normal? Doesn't look normal to me but what do i know. I prodded it with a knife and the white stuff was rock hard. If it's new then it could've solidified over night.
So my question is, is this white stuff normal or has something clearly failed. And while i'm here, would this have anything to do with my rear speakers blowing? They sound fine when i blast music out of them. It just seems on movies they sound like they want to explode.
I will post some pics and i can also post a video of my speakers if anyone needs to see the cone moving the way it does.
Thanks in advance guys and girls.
Jay.
Jay.
