Help! Denon AVR 3805 issue
Discussion in 'AV Receivers & Amplifiers' started by tpc3416, Jan 31, 2005.
Tags:
  1. tpc3416
    tpc3416
    Can anyone help? I'm a newbie to the site, but somewhat knowledgeable of audio and video. I recently upgraded a Sony hi end surround receiver to the new Denon AVR3805. I have read my 100 pg manual 2x trying to figure out why my dts encoded dvd's wont show up as "dts" or "surround EX" on the Denon 3805 receiver display. I've got my Toshiba dvd hooked up from the dts/bitstream out to the Denon's digital coax 1 input, and when I select "auto" it goes to standard Dolby Digital, and not dts. Bitstream does work and I do get sound if I set my Toshiba dvd player to bitstream. Just nothing with the others. When I manually select DTS, nothing plays. The dvd's I am playing are Mummy (dts 5.1), Fast and Furious (dts 5.1), Star Wars II (5.1 Surround EX), and X-Men (THX which should at least register 5.1 Surround EX). Is it possible the Denon is having trouble recognizing dts signals or is there a simple solution to this madness? Thanks! TC
  2. AgeOwns
    AgeOwns
    Jul 28, 2004
    71
    9
    Macclesfield
    Are you selecting the DTS track on the DVD player? DVD's usually play dolby digital as standard and you have to select the dts audio track in the on screen setup/languages menu of the DVD...or press the audio button on your dvd remote when the movie is playing to toggle through the audio tracks (commentary etc) until you find the DTS one....
    ...unless of course you ARE manually selected DTS on the DVD....in which case sorry for being of no use what so ever.
  3. tpc3416
    tpc3416
    For some reason I am not getting that option on the dvds remote on screen display. Although these dvd's are labeled dts, it's not showing up as an option with the remote. You can only select bitstream, pcm, or analogue. When you play the dvd, and scroll through the audio options, there is no DTS. They all showed up with my last receiver. I cant imagine the Denon has anything to do with that, as the signal goes from the dvd to the receiver and not backwards. Usually the receiver will select the best output. I have another dvd player - I'll try that to see what happens. It's the craziest thing.
  4. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    U have to select dts from the main menu of the actual dvd itself. It is normally in audio/language options.
  5. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    This is the menu of the film "I robot"
  6. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    DTS tracks won't ever show up as Surround EX on the Denon display. It will show DTS, DTS-ES Matrix, DTS-ES Discrete, DTS+PLiix and maybe DTS+Neo6. The modes available will depend on what format is encoded on the disc (i.e you'll only get DTS-ES Discrete from discs that are encoded in that format).
    As has been suggested, make sure you select the DTS track from the dvd disc's Audio Option/Languages menu. :)
  7. tpc3416
    tpc3416
    Thanks gentlemen-got it to work. Great site. I totally forgot you have to go into the "language" section of the dvd menu to access dts. You were absolutely right. I have nothing but praises to say about this new receiver, it's power, and sound. They shipped me the old remote with the black foil display and it's unreadable in daylight. Will see if they'll swap it for the new blue one. Next is to bi-amp my RTi10's. :thumbsup: :suicide:
