Help! Denon 2900
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tumbruk, Jan 1, 2007.
  1. Tumbruk
    Tumbruk
    Oct 31, 2006
    12
    I have just bought a Denon 2900 DVD player, and I am having a problem getting dialogue, I do get film score and
    sound effects.
    What I am doing wrong? The connection is through a fully wired scart which I have used before to connect Sky to TV.
    Any advice will be very much appreciated.
    Thank You and Happy New Year
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,891
    2
    The Fylde Coast
    +13,532
    If you are only connecting via Scart (i.e. no AV amplifier), then you can set the 2900 to output for two channel sound only. Enter the Setup screen, select the audio option and then select the two channel option instead of multichannel. See if that helps.
  3. Tumbruk
    Tumbruk
    Oct 31, 2006
    12
    :thumbsup: Thanks for the advice Malice the audio works perfect now :smashin:
